RCA HD52W59 HDTV Projection Television Logo
Posted on Aug 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CHANNEL CHANGES BY ITSELF
MY TELEVISION WILL TURN ON/OFF BY ITSELF AND WHEN IT IS ON, THE CHANNEL KEEP CHANGING.
Bob Citizen
Level 3:
  • Master 520 Answers
  • Posted on Aug 02, 2008
Bob Citizen
Master
Level 3:
Answers
520
Questions
0
Helped
257919
Points
1220
The remote may be malfunctioning. Take the batteries out of the remote and see if the problem stops.
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
My 32" G.E. television can
I have had similar experiences. I have a VCR sitting near the television. I found that if I keep the VCR turned on then the TV stops changing channels by itself. If the VCR is turned off, then it starts again. Weird, but it worked for some reason.
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
RCA P52939 turns on and off by itself
the front buttons are common for going flaky - if you remove the front grill you should be able to unplug them and use the remote only
if you use the buttons let me know and i will look up the board or switch part # all switchs will need to be replaced
thanks
scott
6helpful
4answers
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
My tv changes channel by it self
I have the same problem, anyone with a solution
2answers
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
2answers
Sony kv27fv300 changes channels by itself?
Try unplugging your TV for 8 hours and it comes back to normal. At least it did with mine.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
