My wonderful Bosch has cleaned beautifully for 3 years but recently there is a film inside the washer and on the dishes. I have cleaned the filter, added jet dry, changed detergent. Any ideas?
The problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
heatman101
We bought our Bosch SHE43M four months ago. It worked great for three months, then the white film started - all over our glasses and the inside of the unit. Bosch suggested putting a bowl of vinegar in the dishwasher and running it without dishes, then running the dishwasher 5-10 times w/o dishes. This cleaned the inside of the unit, but the first time we used soap again (1/2 teaspoon of dry soap), the film returned. Our rinse dispenser was full and turned down to 1. We have a water softener installed, so it can't be hard water. What next?
washer runs, pumps in and out . dishes do not clean
