FH Error code Whirlpool Front load washer. I have done every thing that has been posted as far as fixes. I have replace the following parts and still receive the FH Error Code. Flow Switch, Intake water valve All hose connections are fine Pump and drainage is fine Is there a way to test the CMU
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified.
SOURCE: whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
SOURCE: Cant find the flow meter on my he 3t washer
the flow meter usually connects to the dispenser, it is real small and it has i believe mercury inside of it,,,type of liquid.
