Rheem 75 GAL Propane Water Heater PWR Vent 6YR 22VRP75P Logo
Posted on Mar 16, 2011
I have a Rheem PowerVent 2 75 galoon lp gas heater model number 22VRP75P. The vent fan comes on, pilot clicks and ignites, burner does not. After three tries, the unit powers down, LED light flashes twice. After shutting it off at the fan, I have been able eto get it to restart. Is this a an ignition control module problem? If so, what is the part number.
5 Related Answers
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Feb 23, 2009
SOURCE: rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Anonymous
  • 1902 Answers
  • Posted on May 30, 2009
SOURCE: burner & pilot went out, will not go without having a gap in the burner access door
Replace the pilot generator and everything will work again. It is a problem with it sensing the flame from the pilot and when the generator stops working it tends to knock everything out
Anonymous
  • 332 Answers
  • Posted on Jul 08, 2009
SOURCE: 1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Anonymous
  • 68 Answers
  • Posted on Aug 30, 2009
SOURCE: water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Anonymous
  • 145 Answers
  • Posted on Jan 08, 2010
SOURCE: Rheem PowerVent Mod# 21VP40E-1 A S/N 0197106452
CHECK THE POWER VENT UNIT
If I run out of propane, do I need to unplug the hot water until I get gas? Also, how do I get it started again once gas is restored? i have a Rheem PowerVent unit.
There is no pilot light on your power vented hot water heater. You may as well unplug it because the induction fan will continue to run. Hopefully your propane company is responsible enough to perform a gas leak check on your propane system. After the gas is turned back on, you can plug in your water heater to start it up. Run-outs are costly so it's bet to get on automatic delivery or call when the tank is down to 30%
1helpful
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Changing from nat. to lp gas on water heater, changed main burner orfice and pilot orfice and switched the pressure regulator to lp gas, is that it??? the label on the water heater says something about...
YOU MUST FOLLOW THE MANUFACTURERS CONVERSION INSTRUCTIONS EXACTLY. If you do not your homeowners policy COULD be declaired void in the event of a claim. More importantly (IMHO) you could create a dangerous situation!
ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
2answers
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
1helpful
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Rheem Pool Heater Clicks
1) common problem for this heater. Likely the pilot is igniting but the gas valve is not getting the signal back saying pilot is lit so open the main valve to burners. Easy fix with new pilot assembly. Good technician can diagnose this and change part in under 20 minutes.
To diagnose yourself go out after dark (to make pilot easier to see), turn on heater to make it spark. After it sparks 15-20 seconds pilot should be lit. With an inspection/cosmetic mirror you will either see the pilot sparking or lit. It will be in bottom right if burner cabinet, just follow the small silver tubing.
2) Second scenario, Pilot is not getting fuel. Could be clogged pilot assembly, stuck/faulty gas valve, supply line shut off valve not open.
In the event heater is in older, rusty/corroded condition there is the remote possibly of a hole in pilot tubing so gas isn't getting to the right location, just dumping into heater. If this is the case do not loose your eyebrows looking for pilot in scenario one, call a pro.
Top Rheem Pool & Spa Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
