When I turn my camera on, it says internal memory is full but I am using a memory card. I don't know how to delete pictures off the internal memory.
SOURCE: Internal memory is full
Check the settings for the default storage.
On the camera press "Menu".
In the menu go to the camera settings symbol (camera and wrench).
Go to the "image storage". Is "internal" or "auto" selected?
Is internal selected copy the files to the memory card.
Leave the menu. Press "preview". You'll see only pic's from the internal memory.
Press "Menu" ... "Copy" and choose all.
After that go back to "image storage" and choose "Auto" and -if necessary- delete the files from the internal memory (remove the card before!)
SOURCE: Just put 2gb sd card
on a kodak you can also copy your internal photos to card-go to menu and find menu highlight that says storage or something like that and change setting to use card first-when the camera has a card in it it will usuallt default to card first
SOURCE: I have a picture on
Find the function to transfer internal pics to memory card, refer to instruction guide or try to go through settings menu and explore.
SOURCE: camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
How do I access the Internal Memory?
I was using a memory card; it was full; so I switched to internal memory; now I can't use my memory card
how can I retrive my pictures from digital camera that says internal memory full memory full how do I get the pictures
can't get pictures off camera due to internal memory full
SD card only has 12 pictures on it, and all other pictures have been deleted. Is inernal memory something else?
