KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
Posted on Mar 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello. I have a Kitchen Aid mixer made by Hobart between 1975 and 1978. It is a stand mixer with a 5-quart bowl that lifts and locks into place. While it was kneading a bread dough, the motor disconnected from the dough hook which stopped moving. I could still hear the motor turning in the head, so I suspect that the gears are stripped. What do you suggest for diagnosis and repairs? Thank you for sharing your advice and expertise. sincerely Suzann Parker Leist 3-15-11
Anonymous
Level 2:
Guru:
  • Expert 257 Answers
  • Posted on Mar 16, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
257
Questions
Helped
98622
Points
705
Hello Suzann,
I understand that you are having a problem with your Kitchen Aid 5 Quart mixer. It sounds like you have stripped the gears or the worm gear out. Although, it may not be an expensive parts repair it is not an easy task to complete if you are not mechanical enclined. There are many different little gears in these units.
My suggestion would be to take it a local appliance repair shop that works on mixers. If you can tell me the city that you live in I would be more than happy to give you the location of one or two repair shops. As the unit is so old you want to invest in a new unit and keep that one as a reminder of how long Kitchen Aid has been around.
Thank you for choosing FIxYa.com
Justin Burnett
1helpful
I bought a used bowl-lift mixer. It works except the bowl raises 1/3 inch too high before it locks into place. The under head screw doesn't allow a large enough adjustment. Other ways to adjust?
You shouldn't need to mess about with washers, it almost sounds like there is an incorrect part in the mix. Have you contacted the previous owner about the issue?
Find a local Kitchen Aid service agent and they may be able to say what is wrong just by looking at it.
I expect spacers in between the pedestal and lower case would solve the problem but that's not a proper solution.
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Bowl lift on my kitchenaid 5 profesional is slipping
Replace the plastic bowl lift part on that crankhandle inside the pedestal.
KitchenAid KSM150 bowl won't stay put
If the base is not holding the bowl properly then only a replacement base plate or another bowl is going to fix it. The base plate is held onto the pedestal with 3 Philips head screws.
3answers
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
1helpful
3answers
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Mine is a K5-A Hobart Kitchen Aid mixer and the back bowl pin broke off so I can't click the bowl in place any more. Please help!
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
