Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
8. If the same pink line shows when you hook it to another computer, it's a problem with the monitor.
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Good luck.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Flashing yellow light usually means it is not getting the video signal from the PC, try it on other PC first to narrow it down the problem, bad VGA cable can also be the cause, last will be problem in the monitor itself which you will need to open up to inspect the inside. Post back what you find so we can helpou more. More likely to be bad backlights inverter board.
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
anyone able to tell me what this means ?
replace monitor...new video card.....other ???
