I press the market app and it says that apllication market has stopped unexpectedly! I just got this phone over the weekend and I cant seem to figure out why it does that, please help!!
Re: I press the market app and it says that apllication...
Well what you should do is turn the phone off and remove the battery for about 2-3 min.. replace the battery then, try to launch the market app again.. now if that does not work and it continues to crash it may be a defect with the original loading of the app from the manufacturer, because market app is pre- installed on the device before consumer contact... so if its a app you downloaded from market app thats different but if its the actual app market app then you need to take the phone back to where you purchased it and if they cant do a master reset they may need to replace the device if they cant take the bug out of the market app..
iOS: An app you installed unexpectedly quits, stops responding, or won't open
Learn what to do if an app you downloaded from the App Store on your iPhone, iPad, or iPod touch unexpectedly quits, stops responding, or won't open.
Follow the steps below and test the app after each step.
Restart the app
Close the app and open it again.
Restart your device
Turn the device off and on.
Update your device software and your apps
Update your device to the latest version of iOS.
Update your apps:
Open the App Store and tap Updates.
If updates are available, tap Update All.
If asked, enter your Apple ID password. The updates will download and install.
You might need a Wi-Fi connection to update some apps.
Install another app from the App Store
If your installed app won't open, download and install a free app that isn't on your iOS device. This should reset your Apple ID authorization.
Remember to use the same Apple ID that you used to download the app that you're having issues with.
Reinstall the app
Remove the app from your device and reinstall it. Remember that deleting an app also deletes its data.
Wait for the app to download, then open it from the Home screen.
If the download stops, you can resume it.
Contact the developer
If you see the issue again, contact the developer of the app for help:
Find the app in the App Store.
Tap the app and tap Reviews.
Tap App Support.
Information about products not manufactured by Apple, or independent websites not controlled or tested by Apple, is provided without recommendation or endorsement. Apple assumes no responsibility with regard to the selection, performance, or use of third-party websites or products. Apple makes no representations regarding third-party website accuracy or reliability. Risks are inherent in the use of the Internet. Contact the vendor for additional information.
Last Modified: Nov 14, 2014
Talk to a Human
Press 0, then press 5 OR For tech support, have serial number ready. Don't press zero -- say "iPhone Support" (or whatever product you're calling about). The system will ask you for serial number and get you right to someone who can help
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
well obviously the market app wont work until you have an active wireless connection. But it also sounds like the market app is corrupted. Connect your g1 to a wireless network with internet access and then go into settings and tell it to search for updates. That might fix it
Hi yuggaloyeep2,
There is a free app called "SMS Backup" in the android market. This app backs up your text messages and sends them all as an e-mail to your Gmail account. It's pretty simple!
I was able to get out of this state by doing a factory reset on the phone and setting up my Google account again. I had to reinstall all my applications and lost sms history etc. It seems to also work if you do a reset and setup your account on another phone, then the first phone starts working again. Of course you have to find another phone to reset for that to work.
I have not found a way on the web to reset my Google account when this happens. Logging in/out of GMail and Google Talk does not seem to trigger the reset.
Make a list of all the apps you have before you do the reset so you can reinstall them all.
