MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't know which wires to connect and to which slot it should be connected
Lars Olsson
Level 3:
Brigadier General:
  • MSI Master 3,400 Answers
  • Posted on Feb 26, 2015
Lars Olsson
MSI Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1049047
Points
10330
Joe Sherwood
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 25, 2015
Joe Sherwood
Contributor
Level 1:
New Friend:
Answers
Questions
5
Helped
285
Points
9
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
5815
Points
87
The most important cables only FIT one plug. If it fits in one but will not fit in ANY others. Thats probably where it goes.
If you need to know which wires for your case such as front usb slots try this pinout diagram
http://image.pinout.net/pinout_files/standard-usb-pinout.gif
Otherwise you will need to be more specific.
2answers
I want to install daylight rolling lights, how should I wire it to fuse box?
rygO5JPM6h8HWAf9hLz0wbJIlzX6N"> If I am not wrong then this might be the picture of a nissan sentra se fuse box near the battery in engine bay.
Turn the ignition key off. Check a fuse slot with the help of a 12volt tester pen for continuity and find a slot which does not show any voltage. Now turn the ignition key on and check the same fuse slot. If it does show 12 volts on tester pen then its will be your connection point for your DRL's positive wire. Turn the ignition key off and tap your DRL's red wire (+ve wire) to this slot and connect your DRL's black wire (-ve wire) to your car's body. Thats it then....
Have a lose wire on a stihl 021 chainsaw by air filter but don,t know where it goes to
It probably goes to the ground on the choke lever. Remove the air filter and look at the area where the shut off switch is located, you should see a small slot where the wire slides in and connects with a metal piece in the stop position.
I don't know where to connect the sable cable from the hard drive to the motherboard.
I'm not sure what a Sable Cable is, but if you're talking about a cable that from the hard drive to the motherboard look real close with a flashlight and the slots are labeled on the board. Normally if that is the only hard drive it will go into Slot 1, or IDE 1 or SATA 1. Sometimes they start numbering them with zero and if that's the case put it in 0.
Dtc 21 codes check light
This is a dtc for the main oxygen sensor, or MOS heater.
Some models don't have a heater on the sensor, indicated by a single wire connection. If the sensor has a heater, there is a 4 wire connection.
The fix is usually to replace the whole unit. It helps to have the exhaust hot when this is done, but take care. You might also need a long socket with a slot up the side of it.
Replaced starter and when ignition is turned on the starter stays engaged.
Either the solenoid is junk or you hooked it up wrong.
Don't know exactly what you're working on but in general for GMs,
There will be two large connections and one or two smaller connections on the solenoid
On large connection should have been connected to the starter when it was purchased. Don't use it for anything else.
The other larger connection is for the battery positive cable and any of the wires that had a larger eyelet. At least one, maybe two wires.
Then on to the smaller connections of the solenoid.
One will be labeled "S". Use this one for the wire with the small eyelet.
How to hook up a telephone. I need to know how to hook up a telephone from the box outside to the phone jack inside.
In order to do that you need to know on which pair does your phone jack inside your home is connected. In case you don't know or it is not connected then you need drop wire and punching tool to connect. Simply ask your service provider on which pair he has connected connect the drop wire on the same pair and extend it to your phone jack with drop wire.
2answers
I can't figure which wire goes where\w my Belkin Router. There's no manuel to show me how, or where to put the wires!
1.Please look on the rear end of the router you ll see 4 grey and one yellow slot
2.The ethernet slot from Your ISP Modem(Eg Motorola or westell)should be connected to yellow slot on the belkin and computer to one of the 4 grey slot
3.Run the Set Up CD :
4.Check for the light status : It should be green
Which means the router is all set and good to go
21helpful
2answers
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
Alpine TDA 7563 loses presets when vehicle is
You don´t connect correctly the wire for the constant power suply that´s why the memories don´t stand still,always be a yellow one you need to connect to a direct power suply,good luck
1helpful
Dont know how to reinstall all the wires
You will have one RJ11 slot on the router with a Phone symbol
Connect your phone line to it
You will have a RJ45 slot ( a bigger phone cable slot) named ethernet
Connect your internet wires to it
You will have a Round slot to connect the Cable to it
Connect your cable to it
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
