Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
