Check this out.
F25
Desired temperature fault
At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Heater relay defective.
Remedy:
1. Check the heater relay solenoid.
2. Check the heater relay solenoid voltage (12VDC) from the electronic.
3. Replace the electronic, if necessary.
Cause:
Excess quantity of detergent or rinse aid dispensed. Excess foam has developed.
Remedy:
Check the dispensed quantities of detergent and rinse aid. Follow the information given in the operating instructions
F25
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
Cause:
Remedy:
