Nikon Coolpix S560 Digital Camera Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nikon s570 and it drains the battery even when turned off
Anonymous
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Mar 15, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
52
Questions
0
Helped
4883
Points
104
Try replacing the battery. If the camera is still draining power from a new battery, call Nikon directly and explain the situation. They might have you send the camera in and send you back a refurbished model.
Nikon Coolpix S570 - Monitor freezes after pressing any button on the camera body.
The new battery may be really dead (discharged). Please leave battery out for a while and then put it back in and plug in the power plug. (Do NOT push any button on the camera) Make sure the camera CAN CHARGE the battery first. Typically one Green LED lights up and another one flashes. If it does this then WAIT until the battery is fully charged.
What kind of battery do i need for a Nikon Coolpix s570 ??
The camera originally comes with a Nikon EN-EL10 Lithium-ion Battery.
You can find out more details about its features here if you have further questions:
http://www.dpreview.com/reviews/specs/Nikon/nikon_cps570.asp
Hope this helped. Please leave feedback.
My S570 saves pictures very slow,it takes several seconds,even change for faster memory card has not changed the problem.
This could possibly be an issue with the battery. If it doesn't keep a charge well, the camera will take longer to process the image.
I hope this helps!
2helpful
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
2helpful
I have to charge my digital camera by the usb port but it will not charge at all why?
The S570 doesn't have any charging circuitry. Connecting it to a computer's USB port drains the battery faster, since the camera has to communicate with the computer (even if it's only to say it's got nothing to say). The battery MUST be charged outside the camera, using the supplied MH-63 charger.
If you need a charger, you can order one from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213504100
If you want to go with a third-party charger, one such is
http://www.overstock.com/Electronics/Dolica-Nikon-MH63-Charger/3540127/product.html
Can I use software, USB cable, battery and battery charger from the nikon coolpix s550 on a s570 camera?
The S550 uses the EN-EL11 battery and the MH-64 charger while the S570 uses the EN-EL10 battery and the MH-63 charger. The two cameras have different USB connectors, so you cannot use the same cord. You can use the same software with the two cameras.
2helpful
My Nikon S570's lense won't close
Take out the battery. Wait a couple of minuteas and then put it back in and power up again.
2helpful
2answers
My nikon coolpix s570 keeps giving me a waring that says "battery temperature too high" and the camera won't even turn on
The camera will turn itself off if it thinks the battery is too hot.
The manual just says to turn the camera off and allow the battery to cool down.
It is not right for this to keep happening.
If possible I would return the camer to the store and tell them about it, it may need a repair.
You may like to see if it is better with another battery.
Hope this help a bit.
1helpful
I cannot figure out how to remove the battery from the Nikon S570; when I move the orange piece to the side, my finger keeps the battery pressed into place, and if I attempt to use a tool to move the...
Keeping your finger in place to hold the orange piece to the side, turn the camera over. You may have to GENTLY shake the camera, but gravity should pull the battery out.
5helpful
2answers
Can i plug my nikon coolpix s570 into my computer to charge battery
No. You must either remove the battery and charge it in the MH-63 charger or use a nikon coolpix s570. The best bet is to get a second spare battery so that you can recharge a spent battery.
Check
http://www.batteryengine.com/accessories/nikon_coolpix-s570_digital-camera_battery.htm
Please rate this solution. Thanks.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
