Toshiba Satellite A60 Notebook Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba c655: chek cable connection! PXE-MOF:Exiting Intel PXE ROM. No bootable device--insert boot disk and press anz key
Anonymous
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Mar 15, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
118
Questions
0
Helped
16644
Points
427
Maybe the cables are not connected, they may be disattached to the hard disk or optical drive. You can try opening the bottom of your laptop, it usually has a hard disk vent, when you unscrew the cover, you'd see the hard disk, and you could connect it. If this doesn't help, the boot manager of the OS might be corrupted, you should insert your setup disk and choose start up repair.
2answers
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Ok 1. acer; aspireone 2.Wont boot up 3. PXE-E63:Error while initializing the NIC 4. PXE-MOF Exiting Intel PXE ROM 5. No bootable device--Insert boot disk and press any key. Thic pc has vista on i
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
Wont go past first screen
First try this unplug from AC, remove battery, plug in try to boot normally. If that fails Open BIOS, Boot Order or the BOOT MENU, Boot from HDD first, and save changes and reboot, if that fails try a system restore/recovery.
2answers
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
3helpful
Pxe-m0f : Exiting intel pxe rom
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
