SOURCE: Humidifier blows out dust
the manual says that you may have hard water - so minerals in your water. This may be the "dust". Try filtered or purified water.
SOURCE: Kenmore 15408 Humidifier How to Reset CF
Per the owner's manual, you simply unplug your device for 30 seconds. Upon plugging it back in, the CF notification should be cleared.
This assumes you have also changed the filter, of course.
SOURCE: Not using water, filters are dry, doesn't humidify air.
Check your water supply. Make sure the valves are open and/or not blocked. You could have a blocked orifice in the water line by the solenoid valve. Check to see if your humidistat is set high enough. When you replace the water panel could you have accidentally disconnected a wire. Is the door on good. Some humidifiers must have the door closed properly to maintain a proper low voltage connection.
Good luck
SOURCE: Cant find the filter for my kenmore humidifier i
I am seeing these stocked now at Home Depots
