Televison & Video Logo
Anonymous Posted on Aug 01, 2008
I have a Hitachi Ultravision tv model 53udx10b. I'm seeking the remote control code. Can u help? cole
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
220
Points
Hi FixYa Problem,
I found a list of the remote codes associated with my internet provider's universal remote and kept changing codes until I found the one that solved the problem. Thanks for your offer, but I'm okay.
cmwallace42
Lost the remote and need the code for a new remote
You will need to call the Mfg. of the remote control or check its web page and look for the codes. You will need the name of the TV Mfg. and its model number.
I need to replace the lamp on my projection tv HITACHI ULTRAVISION 53UDX10B. it's difficult to find online. i will need to have the part number for the lamp.
Your model is the DP-15 chassis which is a CRT projection so you do not have a lamp like the DLP models do. You have three CRTs Red, Blue and Green instead of a single lamp.
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
60.5 inch ultravision rear projection tv - circa 1999-2000
If you provide model number I can suggest correct remote control to buy.
Can`t get clear picture anymore
Hello dhack56,
Can you post a picture of the screen as the TV is playing, this way I can see if the picture is fuzzy, or if the images are split, all of which classify as not a clear picture. A picture of the screen will help with the diagnosis.
Thank you,
Shuttle83
2answers
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
1helpful
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
