Torin Big Red Hydraulic Shop Press with Gauge Dial  40Ton Logo
Anonymous Posted on Mar 14, 2011
The hydraulic hose connector is broken. Can't find a manual or parts list.
JOHN LAPIER
Level 3:
  • Master 2,602 Answers
  • Posted on Mar 14, 2011
JOHN LAPIER
Master
Level 3:
Answers
2602
Questions
Helped
899809
Points
8635
You can get that hose made at a place like NAPA . The hose is a couple of dollars a foot and the fittings are about 10 a peice Bring the old one with you it takes 10 munites to make
  • JOHN LAPIER Mar 14, 2011
    I belive you mean the fitting on the hose . But if not they also have fittings so bring what you need and they should be able to match it up I used to owen a cheery picker and got all hoses and fittings there noproblem
1997 Town Car. How can I replace a hydraulic pressure hose?
Judi use the right open end wrench on both ends of hose
2answers
Where I can get 1993 infinity j30 power steering pressure hose or it compatible part at low cost?
low cost will be from a wrecker that handles your make of car
hydraulic hose shops can manufacture one if you provide the sample
that will be about 1/2 cost of a genuine hose
genuine as a last resort
1helpful
Peugeot 308 service manual 2008
the parts needing attention will be listed in the service schedule of the book. They will include timing belt, transmission filters ,belts, hoses, hydraulic fluids, power steering filter along with all the other consumables used for a service.
McCulloch FHH20A 2000 psi power washer. I need the part number for the water inlet connector, since my manual does not list a specific parts number.
Since there is no number listed, I am not sure how we can help. Try contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
1helpful
I have a 2003 protege dx.I had no problems till today I pepressed the clutch pedal and it went to floor and did not come up.After looking under hood I could see where a hydraulic hose on lower driver side...
U have a broken hose, replace the hose . Take the broken hose to a parts dealer. Refill the master cylinder that powers the hose,with the proper fluid. One end of the hose will screw into master cylinder.
1helpful
Location of blower resistor on 2003 grand marquis?
Hello, Just follow the wire from the heater fan under the hood. Trace the power wire from the heater fan and it will join a connector midway on the Firewall. It will have 2 screws and 1 electric connector. Tap the connector with a screwdriver handle and see if the part starts working again.
If it does not, get a used or new blower resistor. Work on a cold engine and remove the screws and connector from the part. Temporarily plug in the new part to the connector and turn the Key to run with the fan ON. It should be blowing now. Turn off the switch and put the new part where you can reach it with 1 hand.
Undo a heater hose at the top rear of the motor going in front of the opening for the switch. With 1 hand remove the hose end, then switch parts with the new blower resistor with the other hand and slide the heater hose back on its fitting. Tighten the heater hose.
Then secure the new part into the Firewall and fasten its connector. You should have lost little Antifreeze by working on a cold engine as the hydraulic lock kept the fluid from running out.
This should be all you need to do except clean any spills away.
Washer hose connector is broke can this be repaired
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
You should be able to see a number of hoses, connectors etc that will replace your broken connector.
ISUZU WAS IN AN ACCIDENT. THE PLASTIC HEATER HOSE
Strip it back and replace all the broken items/parts. New or good clean used parts. You do it or pay a repair shop. What is the problem or question. It is broken Fix it
2answers
Brake line diagram
Brake Lines and Hoses
Double-walled steel line is used in the hydraulic lines between the brake master cylinder and the front tube connector, and between the brake master cylinder and the flexible brake hose at the rear wheels.
Double-flared brake lines provide good leak-proof connections.
When replacing hydraulic brake lines, hoses, or connectors, tighten all connections securely. After replacement, bleed the brake system; refer to Section 206-00 .
The wet appearance of the outer cover of the rubber brake hose is referred to as "sweating." This is a normal condition for neoprene rayon braid hose and is not a sign of leakage or cause for replacement of the hose.
Hydraulic Brake System Components — Non-ABS
Item Part Number Description 1 2005 Power Brake Booster 2 2455 Brake Pedal 3 2261 Rear Wheel Cylinder 4 2552 Rear Disc Brake Caliper— (Mexico Only) 5 2B120 Disc Brake Caliper—, Front 6 2B091 Brake Pressure Control Valves 7 2140 Brake Master Cylinder
Top Torin Big Red Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Torin Big Red Air Tool and Compressor Expert? Answer questions, earn points and help others
