Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
