Question about NorStar M7324 Telephone
Norstar m7324 phone. We have an office with many of these devices, and some of them do not have the audible ringing functioning. How do we change this? I have tried Funtion *6 and changing the ring, as well as function **226344, but the series of steps I was told do not appear on the phone.
SOURCE:
SOURCE: No ring and appear on my Norstar M7310
I just found out how to do it - it is pretty simple
dial "Feature * 6" from your phone
you can choose the ring type you want by pressing next or 1, 2, 3, 4
then press OK
to adjust the volume
dial "Feature * 80"
then press the volume up or down to the desired volume
Posted on Nov 07, 2008
SOURCE: Our office has 13 phones
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
Posted on Jan 03, 2009
ynotphone
  • 192 Answers
SOURCE: Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Posted on Mar 20, 2009
consultel1
  • 860 Answers
SOURCE: Norstar m7310 I would like to set more phones to ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
if the programming doesn't look like 1 described call me @1.410.984.4840
Posted on Mar 25, 2009
consultel1
  • 860 Answers
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
Posted on Sep 21, 2009
How do I make one extension on my Norstar M7324 phone system ring?
Hi J,
Do you mean how to make it ring when someone calls a specific phone number, or when someone calls the specific extension?
If for a phone number, then you need the line to appear and ring on the phone. Let me know which one you're doing.
May 14, 2014 | NorStar M7324 Telephone
Can I change the ring tone for just one of the lines on my nortel norstar phone m7324?
If your phone system has 6.1 software or up then yes,the tech or vendor can program it for you. If you know how to program look under Config/Lines for Ring Type.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
Norstar m7324 won't come off night ring
Is the button still programmed?
Do F871 in meantime....F#871 on older systems helps too or just F87.
Program button:
F*3
button
Feature
871
Jul 23, 2012 | NorStar M7324 Telephone
Our phone system rings three times (on the caller's end) before the standard greeting connects. We use Avaya and Caller ID and it seems it is standard with that program and calling feature that the...
Is this an IP Office?
This is how it works. For some reason the IP Office waits for teh first 2 rings to get caller ID, and then lets the call ring in.
Sep 07, 2011 | NorStar M7324 Telephone
How do i reprogram my norstar m7324 to change extensions names an
Apr 03, 2010 | NorStar M7324 Telephone
I need to make them ring
First check and see if the ringer is on or the volume is turned up.
1st press Feature *6 Press number keys 1- 4 to hear different ring types
2nd - check your volume (Press Feature *80 press volume key up or down
Jun 23, 2009 | NorStar M7324 Telephone
MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Jan 07, 2008 | NorStar M7324 Telephone
Norstar Phone System - How do I change the time?
press feature **time
enter the time.
Press Feature **date
enter the date
Nov 05, 2007 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
70 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
