Check the throttle trigger assembly for free play. You may have to remove the handle section over the trigger to remove sawdust/dirt. Idle changes are usually due to air leakage behind the carburetor--check all fasteners on the carburetor including the ones holding the carburetor to the cylinder. Check the muffler and air cleaner for plugging. Check the cylinder for looseness to the crankcase. Check the throttle return spring on the carburetor to make sure that it is working correctly. Hope some of this helps!
Remove the air cleaner assembly so that you can see the action of the throttle mechanism. If nothing around the carburetor throttle arm is broken or out of place (the return spring), then remove the screws in the throttle trigger part of the handle and look for sawdust blocking throttle trigger action. Hope this helps!
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem homelite then model no. hopefully this will show you correct way.
