Question about Pramac 5000 Watt Generator
I am looking for a repair/users manual for a 5000 watt Generac generator. Model # 6247-8. Also need a wiring diagram. I believe it to be a 1978 model, as it is in our 1978 motor home. Serial # 0402867.
    Novelist:
  • 185 Answers
Posted on Mar 15, 2011
SOURCE:
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    I need a wiring diagram for a generac gp15000e generator
    I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
    Nov 05, 2011 | Generac Guardian Ultra Source 15,000 Watt...
    I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
    The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
    http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
    http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
    Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
    When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
    You can also order the 080270 tank valve here:
    http://www.jackssmallengines.com/searchdb2.cfm
    If you enter the part number on the search page.
    $4.60
    Thanks for using FixYa.
    Kelly
    Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
    Need onan marquis 5000 model 5bgmfa26105f wiring
    Give me to full model and spec # and I will email you a service manual.
    Nov 04, 2009 | Watts Onan Portable Generator - 5000 ,...
    I have a Generac portable generator 5000 watts, won't start!
    I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
    May 08, 2009 | Electrical Supplies
    How do i flash my generac 5000 power plus generator
    well I have a special flasher unit but I believe you can put 12 volts to the brushes while it's running. That should do it.
    Apr 09, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
    Pramac 5000 Watt  Generator Logo
    796 people viewed this question
    Top Pramac Electrical Supplies Experts
    Marvin
    Marvin
    Lawrence Oravetz
    wadingriver
    wadingriver
    Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
