NorStar T7316E Corded Phone Logo
Posted on Mar 14, 2011
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
9357
Points
55
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Testimonial: "Thank you for your quick response, and help! Its most appreciated. So, for my next question How do I program the M7310 :)"
How do I turn the volume of the ringer off on Nortel T7316E. I don't want it on 'do not disturb' as I need to take calls/allow them to go to voicemail, but don't want to hear the ring.
Two different options,... Call the extension, and while it is ringing, press the volume down bar until you can no longer hear it ringing. You can also try this... Leaving the handset down, do Feature * 80, adjust the loudness for ringer volume by pressing the volume bar.
3answers
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
How do I get my phone to ring
Maybe you set the Do Not Disturb by mistake. press "feature #85"
or maybe you call forwarded it. press 'feature #4" or turn up the ringer 'feature *80'
Nortel t7613e can't ring again
When you call an internal extension and the extension is either busy or ringing, you can invoke the Ring Again (Call Back) feature. If Ring Again is activated when the dialed extension is ringing, you will be notified when there is activity on the phone and the phone becomes idle. You cannot use this feature on outside lines, and while your phone is idle.
2helpful
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Nortel T7316E ringer
It always will. Now you need to go into system programming and program the phone to NOT ring.
34helpful
How do I turn off the ringer on a Nortel T7316E?
If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn DND off)
Turning off the ringing permanently will require you to program the set. Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring press CHNG til it says appear only.
press next key (lower right arrow)
The display should say line 002: appear & ring
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
2helpful
My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
1helpful
Nortel T7316E
You have to go into programing to terminals and sets type in the local whos ring was turned off and turn back on . If you can,t get in to programing let us know.
4helpful
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
