JVC FS-2000 Shelf System Logo
A
Anonymous Posted on Aug 11, 2005
How to set a station with the remote control
Of course I can't find the damned manual! I can't seem to figure out the button sequence to set a "preset". How can I program a button to tune in a specific station, like "91.5" for instance. Thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 11, 2005
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
4220
Points
27
1 Tune in the station you want to preset..(use >> >>
3answers
How do i program this remote to my tv
You should find in your Universal Remote user's manual the code for brand of your TV and follow indicated procedur. Of course, you need the manual. Hoe you have it
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
2answers
Have a denon avr 3300 with no remote, how can i program radio stations
Hi hodgie00,
Sad to say but manual/auto tuning set-up can only be access through the remote control button. There is no button in the front panel that can access the command to this set-up. Also this is stated in the Denon AVR-3300 manual.
Click this LINK to have the replacement remote control if the original was already faulty or misplaced.
Hope I helped you.
Have a nice day!
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
2helpful
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
Setting stations
The only way I know how is to use the remote. Manually set your station using the multi function button(the larger round one). then press and hold one of the number buttons on the remote until it beeps. Usually two seconds. your station should be set. Then adjust and repeat.
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
