Sorry and please don't take this the wrong way but is it possible that there is still a blockage in the siphon tube of the conditioner tray part of the dispenser?
Please follow my (complete, pre-typed) guidance notes, paying particular attention to the sentences in BOLD ;-0)
If it's not blocked it is possible that the water is not being fed into the conditioner tray. It is possible to check by opening the dispenser a little way when the machine is on (final?) rinse and you should be able to see the water entering the conditioner tray. If it isn't, it's a service call, sorry.
Remove the complete drawer. To do this you will have to do one of the following-
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Testimonial: "thank you for your advise I will give it a go. Thanks again "
We had the same problem , if you remove the draw and fill the conditioner section from the tap until it siphons out that proves that the tray is OK. We then cleaned the area above the conditioner section where the water comes in but that wasn't the whole solution. We then filled the conditioner section with water on top of the conditioner to just below the siphon , this worked ! and the conditioner went into the mc proving that some water came through at the right time. We then poked a flexible piece of copper wire up the water inlet pipe above the conditioner section and on the next wash a lump of black gunge was in the tray !! success at last. It now works OK with normal amount of conditioner in the tray.
