How do you fix the time and date on Panasonic KX-T7730? Model # is KX-T7730-B. Thanks.How do you fix the time and date on Panasonic KX-T7730? Model # is KX-T7730-B. Thanks.
I have installed 13 units of panasonic KX-T7730 along with PBX KX-TES824 in my office; we need help in adjusting the date and time. The given manuals do not show how to adjust the time/date.
Any one knows how to do that?Hi All;
AnonymousSep 18, 2008
I can not change the date and time on the phone.I can not change the date and time on the phone.
AnonymousSep 19, 2008
changing the datechanging the date
AnonymousSep 22, 2008
How to change the date and time, please help
AnonymousOct 03, 2008
I have the same problem and cannot find a manual to reset/change/alter any of the settings on the phone. Please helpI have the same problem and cannot find a manual to reset/change/alter any of the settings on the phone. Please help
AnonymousMar 18, 2014
how to store contacts detailshow to store contacts details
You can't post conmments that contain an email address.
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
Press Program
0
you will see a display (January 19, 2011 - display 110119)
enter your date (don't press any other buttons, the phone will do in sequence)
YYMMDD
enter day of the week (1-Mon, 2-Tues, so on)
enter time (don't forget to enter 0 if like 9:30)
0930
enter AM or PM (0-AM, 1-PM)
0
then press store button
then press program button
you should see your date and time display
Basically, there are 2 ways of programming the date and time - the short way and the long way. If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system:
SHORT WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM 0 2. Enter Date and Time ( The format is: yymmdd, 1 to 7 1=Monday 2=Tuesday etc, hh:mm, 0 or 1 0=AM 1=PM ) see example 3. Press AUTO DIAL / STORE to save your changes 4. Press PROGRAM to exit program mode
EXAMPLE: If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows: 100203 2 02:15 1
LONG WAY: From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook: 1. Press PROGRAM * # followed by the system password ( default is 1234). 2. Now press 000 and then SP-PHONE. Enter the year. 3. Scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. 4. Now scroll right again and change the date and day. To change the day, again use AUTO ANS / MUTE 5. Scroll right again and the time will appear. Set the time. To change am/pm scroll to it, and again, use the AUTO ANS / MUTE button. 6. Press PROGRAM to exit program mode and you are done.
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done. Please rate this answer if it was helpfull. Thank you.
The chances are, if you have CID you don't have to worry....the first call after 3am will fix it. If not, programming from extension 101 and 000 will fix it.
Any industry standard cordless phone will work on a Panasonic system...are you plugging it into a system phone port with the sytem phone? If you are trying to make both work on the same port, you have to tell the system that. Program option 610 in a TA series or 600 in a TDA series will set a Paralleled phone so both can work.
If you don't know how to get into System programming, your installer or dealer should.
It is a Panasonic Adv Hybride System KX-T7730
Hi All;
changing the date
