You would have to test for 12v at the starter. If you have none there when a assistant turns the key you need to work back thru the wiring until you find 12v where the voltage stops is the defective component.
You can verify it it's the clutch switch by bypassing (unplug electrical connector and run a small jumper lead between connectors)
