11480 if you are using an XFINITY Motorolla Set Top Box with an XR2 remote and the TV model above
However, trying this one remaps the TV input button to Night mode.
11947
Then trying Setup until green lights flash, and entering 11250 somehow resets it.
Hello there,
The codes you tried are for Panasonic TVs. You need to try the codes for Panasonic TV/VCR combos, which are:
21062, 20035, 20162, 20225, 20614, 20616, 21035
I'm assuming you have the instructions for entering the codes into the remote. Please try the codes listed above then let me know if you need further assistance or the programming instructions.
Hope this helps.
Regards,
BElectric
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
There isn't one. It came with an upgrade by Suddenlink called the Suddenlink digitalink (for televisions without set top boxes.
The new remote and Suddenlink DigitaLink manual has aname...sorry, it's Universal Electronics, Delta Universal Remote control. They require a 5 digital code and gave the following codes as possibly workable for Panasonic. They were: 10250 10051 10055 10162 10226 10375 11310 11410 11919.
None of these worked for my installation.
I have a Panasonic roadshow tv vrc combo without the remote. This is what I did to get the front aux audio and video lines working so I could connect a DVD. You need a charter remote (or, at least that's what worked for me) The steps were: 1. Turn the TV one and then Press the mode key for the device you wish to set up: I used the AUX key. 2. Press and hold SETUP until the mode (AUX) key blinks twice. Enter 991 using the digit keys on the remote. I then pressed power a few times and the TV shut off. Success! Now, charter lists a few other steps on their website regarding these setup steps (feel free to take a look for yourself) but I found all I needed to do were follow those three steps and it worked :) Also, at the end, I pressed Setup to save the settings in the remote. Now, the only issue I had was the up down etc buttons on the remote didn't work: they did, but they ran the VCR. However, it didn't matter because once I was able to get into the tv's menu I was then able to use the volume and channel buttons on the TV to navigate around. Hope this helps someone.
