Televison & Video Logo
Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest internet research has led us to think it may be the coax. Can you help?
  • jacqs mum Aug 02, 2008
    As we have had so many differing opinions and tried so many different solutions I would welcome all input into this problem.
    Thank you.
Anonymous
Level 3:
  • Master 2,071 Answers
  • Posted on Aug 02, 2008
Anonymous
Master
Level 3:
Answers
2071
Questions
Helped
1015261
Points
5371
SERVICE MENU SETTINGS
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below.
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
panel
Displays panel resolution
power on time
Displays total working time of the set
backlight on time
Displays total backlight on time of the set.
calibration menu
By pressing “◄/►” buttons select the second icon. calibration menu appears on the screen.
color temp
By pressing /. button, select color temp. Press ./. button to set the color temperature. The
options are: 5500K, 6500K, 7500K, 9300K and user.
user color temp
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values.
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
979326
Points
3981
A weak signal can also cause this problem. Better have a tech to figure out or try another antenna installation.
Anonymous
Level 3:
Master:
  • Master 382 Answers
  • Posted on Aug 01, 2008
Anonymous
Master
Level 3:
Master:
Answers
382
Questions
0
Helped
93252
Points
1022
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
Anonymous
Level 3:
  • Master 10,594 Answers
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2956951
Points
33084
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
  • Anonymous Aug 03, 2008
    My suggestion is still same.
TV showing color pixels but no picture and no sound
Well at least you didn't pay for the TV. Your panel is defective. Cheaper to buy a TV than to fix.
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Phillips Plasma Tv 50pfp5332d/37 has red pixels but no picture,what is wrong
if you are using a HDMI cable and it is just the picture not the tv controls that is red, the cable might be loose, but if it wont do anything and the tv controls don't show up or anything than that's not the problem
Panasonice TV freezes and stutteers off of cable when in HD
if the picture keeps breaking up and pixelating it is normally a reception issue rather than a problem with the tv.
1helpful
Phillips 42", LCD TV Cuts out and skips on HD, including sound
if pix is breking up in small squares, freezing then going back to normal, tha sonds like a cable problem. to verify this, use video-1 input for cable box and see if the problem occurs. if it does unhook cable box from tv video-1 input and plug dvd player into that same input. if it never breaks up on dvd, the problem is in cable signal. if still breaks up tv is problem. mch
Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
2answers
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
