Could you let us know when this error pops up. and what all you have tried
Thanks
proton
This particular error comes when:
Framing error ,parity error, or an overrun error happens, at the time of data reception. The protocol setting must be correctly made to match the computer settings
The user manual for the your equipment can be found at the following link
http://www.rolanddga.com/rnet30/files/su...
Thanks
Proton
In case you are still not able to correct the setting , you may need to contact the Roland support people as there could be a hardware problem on the cutter. Contact them here :
http://www.rolanddga.com/color/support/e...
Thanks
Proton
Tel
800-542-2307
949-727-2100
Fax
949-727-2112
Thanks for telling me that...
Do rate the solution....and let me know what Roland tech support has to say on this
Thanks
I switch on main switch and the machine automatically goes through its loading proceedure, I then load the paper and dial to "edge" then press "enter" and the machine identifies the paper location and should then go to show cutting width on the display
however it shows the error Er15:RS-232Err
This happens regardless of any signal from the computer, and even when it is completely isolated from the computer.
None of the control keys work except the position keys which have no effect on the problem.
Thanks
John
Thanks Proton (Greek for FIRST) did you know? appreciate your help. Regards
John
download the software:
cutstudio and work with that-
SALUDOS ANDRES de KERNEL informatic@
