I had the same issue with my Dell XPS 15z, after looking every where to get instruction to get the CD out. I decided to call Dell Tech Support and it did work. 1. Turn off the laptop 2. Turn on the laptop and press F2 several times until the setup menu come up 3. Then press the eject botton from the keybord, the Cd should come up. Good luck
Look at the front door of your CD drive and you will see that there is a small hole.
Take a paper clip straight it out and push it inside the hole.
You will have to force little bit but without exaggerating you should able to open your CD.
If you really feel that you need to force a lot do not continue and bring it to an expert to open it.
Best regards
