This problem is as a result of a bad control panel. The control panel
controls all the functions of the unit it accepts commands and executes
them. Often times it would accept a command but not execute as a result
of malfunctions on the control board. This is why atimes it comes on and doesnt function. The control board is not totally bad but suffers from partial failure therefore the problems.
Best solution is to get the control board replaced this can be done by any service repair personnel or simply contact the nearest dealer for a repair person. Would have told you to try getting the boad fixed but that will only be a temporary solution as the problem will re surface in no time.
Hope this solution has been helpful?
I need the complete brand and model# to help you.
there is a label at the frame usualy at front or side. I need the number from there to search for parts and tech info.
your information is correct. but sadly I can not get any information on your equiptment here. looks like you live outside of the USA. wich is where I am. I tried all of my resources with no luck. sorry. perhaps someone else can help you here.
The electric treadmill brand is - Elite Fittness Equipment model No. T-1720
The info. plate attached to the treadmill reads Elite T-1720 N.14212
Input 220-240 AC 50HZ
Rated output 0.93 KW
Rated Current 5 AMPS
There are no other numbers or information on the machine
Yes, Australia.
Thank you for the information regarding the control board. As you pointed out it is causing the problem and I will contact a repairer in Australia.
