Cameras Logo
Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello i am using a polaroid izone 310 and i just found out that it can record video clips. I added a 1GB SD card to the camera and recorded a clip. The only problem is when i upload it to my computer the video doesnt have any volume. Why is that?
Gayle Ashbach
Level 3:
  • Master 876 Answers
  • Posted on Aug 01, 2008
Gayle Ashbach
Master
Level 3:
Answers
876
Questions
0
Helped
252445
Points
2306
Are your speakers turned on? is the volume turned up on the media player? is your sound card volume turned up (check lower right "megaphone" by clicking on it.
I captured 6 video recordings, but only 4 will download. The two remaining ones are each 20mins in length. Only the short videos will down load to my computer.
I had a similar problem with my D-90 when I attempted to down load several video clips from the SD card in a card reader. Don't know why this happens but I was able to get the long clip by manually copying it from the SD card to a folder on my computer.
I then manually deleted the video file from my SD card. Until I read your problem, I could not figure out why that particular file would not download like the rest of them did. The other clips were 19 minutes but the long one was 22 minutes. It appears the limit for auto downloads may be 20 minutes. I have another camera that breaks long videos into 19-minute clips and I suspect the reason 19 minutes is the length is because of this aspect of Windows.
1helpful
Can't get full use out of 8GB SD card.
There is no problem. The camera can only create video clips up to 4GB in size. You can record two long clips, but no single clip can exceed 4GB.
Need the operations manuel.
Polaroid IZONE 310 Digital Camera
To download the manual use the link below:
http://www.mediafire.com/?q25l6caacs2dkpr
Note: You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site .
3helpful
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
What is the capacity sd card for a polaroid izone 550
izone 550W has 16MB own internal memory. In addition it takes SD-cards. I'd say since it's quite a new model it'll handle at least 8GB card which is more than adequate (over 2000 frames on highest resolution)
Polarroid 310 izone
Polaroid has a PDF of the user's guide on their site. I'll post a link
It's 84 pages long. Enjoy! http://www.polaroid.com/service/userguides/digital/cameras/izone300_ug_en.pdf
Polaroid izone 300
I left my izone 310 in my glove compartment during hot weather and now it is doing the same thing. I am planning to buy a new camera, unless someone comes up with a solution soon.
2answers
Taking video clips
hi, It should not problem with flash card but while you placed it some setting must have changed Sangita
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
