Start the email application you are using, press the menu button, and select accounts. Hold down your finger on the account you want to remove, and when the option pops up, select "Remove Account."
1) Go to settings 2) Select applications 3)Then select Manage applications 4)then go to the Email application and select clear data option .If the application running means pls force stop the App before clearing the data.Confirm. 5) Your email accounts will be deleted.
This should work for the Google mail account that you use to set up the phone, as well as any Microsoft Exchange accounts you may have set up.
From the Home screen, press the menu button, then settings. Scroll down and select Accounts & Sync. About halfway down the screen there is an option to "manage accounts", select the account you wish to remove and click "remove account" on the bottom toolbar.
If you wish to remove an IMAP or POP3, navigate to the default Email app on your launcher screen. Press the menu button and tap accounts. Tap and hold the account you wish to remove and select remove account.
