Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
Anonymous Posted on Mar 12, 2011
The power went off on my frigidaire gallery gas stove now that the power is back the screen in flashing PF and would not respond to any touch
Paul Bade
Level 3:
  • Frigidaire Master 1,818 Answers
  • Posted on Mar 12, 2011
Paul Bade
Frigidaire Master
Level 3:
Answers
1818
Questions
Helped
574149
Points
5816
Perhaps the power did not come on cleanly (lots of surges, dips and sags while it was reconnected). This could result in improper power on reset in the stove controller. "PF" probably indicates the oven was on at the time of the last power failure (signals baking was interrupted abnormally), or the previously described reset problem.
Try unplugging the stove and plugging it back in, then press the CANCEL button if you don't see the normal display. Press the Clock button, enter the time using the number pads, then press Start.
If you don't have the manual for your oven, you can download it free from Frigidaire, but get your model number first (open the drawer at the bottom and look around in there if it isn't posted on the oven door frame). There are at least half a dozen models in this series. When you get the page for your model, click on the Guides/Manuals tab.
John Tripp
Level 3:
  • Frigidaire Master 4,656 Answers
John Tripp
Frigidaire Master
Level 3:
Answers
4656
Questions
Helped
1677641
Points
14883
I can tell you the codes but being they are listed here=> Frigidaire Gas Range Fault Codes Electronic. They have 4 versions, Thanks Sea Breeze
  • John Tripp
    John Tripp Mar 12, 2011
    Your indicates Power Failure, Reset time will possibly clear that, Sea Breeze
    Send model number and I will look for a user manual. Thank You
Hey guys....My Fridgidaire Gallery dishwasher is locked closed and has pf code on it....now what?? Thank you!
Cutting the power for 5 minutes, usually releases the lock.
Your electricity voltage is too low.
Frigidaire Dishwasher Error Code = PF Check / Repair / Solution = A power failure has occurred. More than 10% of power has dropped to the unit. Check house wiring.Feb. 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To ...
How to Fix a Frigidaire Gallery Dishwasher With a PF Code ...
https://www.hunker.com > ... > Dishwashers
Step 1. Check the other appliances in your kitchen for power interruptions, as an indicator of what might have caused the "PF" error for the Frigidaire dishwasher.
FIXED - PLD2855RFC0 Frigidaire - PF Error Code ...
https://www.applianceblog.com > mainforums > threads
May 22, 2013 - I'm getting the "PF" error code at the same spot... ... Brand: Frigidaire ... verified the heating element has excellent continuity and ... What fixed it for me: I replaced the circuit breaker of the dishwasher on the outside power panel. ... When the door is closed, it gives a PF error and flashes a few times. If I open ...
Frigidaire Dishwasher Error Codes Explained
https://howtofixit.net > frigidaire-dishwasher-error-code...
Feb. 10, 2020 - This is a guide on what Frigidaire Dishwasher error codes are and what ... To fix this error code try opening and closing the dishwasher door to reset the cycle. ... When the i30 error pops up it is saying that the bottom pan has a leak to it. ... that you will run into will be power failure, this is under the PF code.
Mar 03, 2021 • Dishwashers
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
2helpful
3answers
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
10helpful
2answers
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
9helpful
3answers
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 • Ovens
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
