Your chain brake is locked up. It needs to be replaced. There was a recall on these.
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Check there are no kinks in fuel line.
Make sure that the air filter isn't blocked.
Check the throttle cable is operating the throttle plate in the carburettor ok.
Ensure chain isn't too tight.
The carburettor should be a tight fit on the air inlet manifold.
It's possible that some of the jets could be blocked in the carburettor. You can try and clean these with compressed air but ensure you remove any seals gaskets, springs on the diaphragm pump , primer bulb etc as they can be damaged by the pressure.
