Kettler TX1 Treadmill  with FREE INSIDE Delivery! Treadmill Logo
Anonymous Posted on Mar 12, 2011
The running belt on my kettler marathon tx1 treadmill wont run once I get on it. Once I step off it runs smoothly?
Anupam Datta
Level 2:
Sergeant:
Champion:
  • Expert 263 Answers
  • Posted on Mar 12, 2011
Anupam Datta
Expert
Level 2:
Sergeant:
Champion:
Answers
263
Questions
0
Helped
34074
Points
618
Use grease and check if any lock is there
  • Anonymous Mar 12, 2011
    I greased it and there is no lock
  • Anupam Datta
    Anupam Datta Mar 12, 2011
    Tighten the nuts.before that disassemble parts and then again reasseemble
Kettler Marathon ST threadmill stuck on blinking HR
If your Kettler Marathon ST treadmill is stuck at the blinking HR (heart rate) screen and is unresponsive to button presses, here are a few suggestions you can try to troubleshoot the issue:
  1. Check the safety key: Ensure that the safety key is properly inserted into the console. The treadmill may not respond if the safety key is not properly engaged.
  2. Reset the treadmill: Locate the power switch or unplug the treadmill from the power source. Leave it unplugged for a few minutes to allow the internal electronics to reset. Then, plug it back in or turn the power switch back on. This can sometimes resolve temporary glitches or errors.
  3. Inspect the console connections: Open the console cover and check the connections between the console and the rest of the treadmill. Make sure all cables and connectors are securely plugged in. Loose or disconnected cables can cause communication issues and affect the functionality of the console.
  4. Clean the console buttons: Over time, dirt, dust, or debris can accumulate around the console buttons, preventing them from registering presses. Gently clean the buttons and the surrounding area using a soft, lint-free cloth. Avoid using liquid cleaners that could damage the console.
  5. Perform a console reset: Look for a small reset button or hole on the console. Using a paperclip or a similar object, press and hold the reset button for a few seconds. This will perform a console reset, which may resolve certain software or configuration issues.
  6. Consult the user manual: Refer to the user manual or documentation that came with your Kettler Marathon ST treadmill. Look for specific troubleshooting steps or contact information for technical support.
My kettler tx1 marathon running machine causes the electricity to swith off in the house. This occurs when I start the treadmill, not when I simply switch it on. Any idea as to the cause?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Belt motor
see the video attached . Lube the rollers bearing front +back too.
God bless you
Problem with Kettler Marathon ST, error 01 and not starting
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
sincerely. GOD bless you
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email [email protected] or www.kettler.co.uk
9helpful
2answers
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Top Kettler Exercise & Fitness Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
