Checking virtual IP servers...
[VIP Raw] Connecting to Virtual IP server 98.136.48.32...
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
*** 'COMPONENT_TYPE_WININET' value: '12017' *** [PASSED]
[VIP Raw] Sending HTTP request to the server... [PASSED]
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] PASSED *** 67.195.186.245 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] Resolving host name login.yahoo.com... [PASSED]
[Login] Connecting to login server 69.147.112.160... [FAILED]
*** 'COMPONENT_TYPE_WININET' value: '12029' ***
[Login] FAILED
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
SOURCE: cant login to y.m but can connect to internet,
I would like to help you with your issue. but we have to check the following first
http://webmessenger.yahoo.com/ try log into the Web Messenger
> Step 1: Test Your Internet Connection
> Step 2: Verify Your Yahoo! ID and Password
Open Internet explorer and www.mail.yahoo.com
Check by sign in to you account
> Step 3: Test Your Access to Secure Pages
Make sure that you can access secure pages from Internet Explorer
Try to sign in to Yahoo! by going to the Yahoo! sign in page and enter
the same Yahoo! ID and password you were using before.
> Step 4: Verify Credentials
Verify that the same Yahoo! ID and password you used before in the last
step also works in the online version of Messenger, Yahoo! Messenger
for the Web:
enter the same Yahoo! ID and password you were using before.
> Step 5: Check Connection Settings
Click the Messenger menu and select Connection Preferences.
Click Connect directly to the Internet, and then click OK.
Check by Changing the connection type to a connection via a proxy server:
Click Connect via a proxy server, then under this option, select HTTP proxy, and then click OK.
Last is Uninstall all the Yahoo Tool Bars and Yahoo applications , Yahoo Messenger, and Yahoo Updates from Program list i.e Control panel - Add/Rem Programs ..
And reinstall the Yahoo Messenger again -
Hoping this article will be helpful for you
SOURCE: hi cannot able to connect
Please uninstall the messenger, download and install latest yahoo messenger and try. Still if you are failed, try login with http://webmessenger.yahoo.com, let us know the result.
Thanks for joining us.
Have a good day.
