SOURCE: Maytag Neptune MAH8700AWW Front load
You must be on the right track, must be a blockage at the back of the soap drawer, check if junior has posted a toy car! If not turn down the water pressure at the machine stop tap
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
SOURCE: my maytag neptune washer model
Look carefully in the inside front of the dispenser. You should see what looks like a red plastic string. (the type of string used on a power string trimmer) Pull on this string and the door should release.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
SOURCE: Maytag MAH8700AWW will not dispense fabric softener
I had the same problem, all the water dispensing worked except for the fabric softner one. It was the wax motor. I tested it first by switching the wax motor for the bleach dispenser to the fabric softner dispenser and turned the machine on to the point where the fabric softner would be added. I hope this helps someone, to save them money and the hassle of dealing with repair men. I have had my neptune front loader for 10 years and this is the thrid repair needed luckly it was an in expensive one the first 2 were major! So much for maytag being sooo good!
