Ibanez Tbx150h Tone Blaster Xtreme Guitar Amp Head Logo
Posted on Mar 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Ibanez TBX150H head, when I turn it on all I get is a buzzing noise coming through the speakers. Nothing drastic happened to it, just one day it wouldn't play.
Fred Yearian
Level 3:
  • Ibanez Master 5,603 Answers
  • Posted on Mar 12, 2011
Fred Yearian
Ibanez Master
Level 3:
Answers
5603
Questions
Helped
2250322
Points
16163
Most common cause would be failed filter capacitor(s). Broken grounds neaar the input connector are another common problem. This will take electronic troubleshooting skills.
Preformance of ibanez 100 watt toneblaster head
What is your question about the Ibanez Toneblaster head?
Y Does this Sound Like A Fluttering Or F@rting Ibanez WD7
The truss rod in the neck needs adjusting to rid the buzzing sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
1helpful
I am trying to wire a Delano 4 conductor pickup with a simple volume and tone control harness wiring into my Ibanez Bass guitar. I am new at this and just getting a buzz when testing.
If you are getting a buzzing sound, the ground connection is wrong. If you google how to wire an electric guitar there is a lot of info on it.
Barrel socket noise/squealing
I would try a different guitar cord to prove that the one you use is good. If the plugin socket is rusty or corroded it could do the same. If you use a speaker cable as an instrument cable, that would happen. A loose ground can also and cheap pickups will do it naturally. I know an S series should have decent pickups but, if you got it used or something like that, you never know what was done to it before you got it.
2answers
Well i used to have this really bad guitar that has this grounding problem (humming all the time unless u lower the tone or touch the strings or any metal object on it) well i always blamed the guitar for...
This would only mean two things:
1. you have a bad capacitor in the circuit or the grounding on the circuit is broken and not filtering the obvious line noise from the circuit.
2. You have what is called, dirty power. That is when you have some kind of electrical device plugged that generates line noise which can be even a florescent light as they generate line noise.
Please take the following steps to narrow down the issue.
Take your setup and plug it in some where you know others can setup their rigs and it is using clean power. If, the humming goes away then it is dirty power where you originally setup.
If, it is still humming then you will need to take your equipment to a qualified marshall dealer have them look at it.
1helpful
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
Cant get the fuse out
The fuse is in a "boat" right next to where the power cord plugs. Pry outward on the tab of plastic where the power cord plugs in. The tabe is about 1/4 inch wide.
IF THE FUSE HAS BLOWN, better find out why as replacing it MAY cause further damage to internal components. If you do replace it and it blows again, take amp in for servicing.
Ibanez artist guitar circa 1983. buzz in string. bowed neck. not sure how to adjust rod. bow is like a hump rather than valley.
The rod is probably broken - this causes the buzz and the bend in the neck. Replace the neck.
Top Ibanez Music Experts
Ngoro
john h
Are you an Ibanez Music Expert? Answer questions, earn points and help others
