Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
problems with the choke, to low fuel float level in carburator, timing to retarded or just problems with your battery or starter if it doesnt crank fast enough
Next time when cold and it will not start remove a spark plug or two and see if the engines flooded. If so there are two things that come to mind; 1, worn injectors, leaking as engine sits with time causing difficult starts 2: bad oxygen sensor, if failed engines tend to run rich and the ECU may have your injectors pump heavy amounts of fuel to keep from running lean; often times you'll see poor fuel MPG if O2 sensor failed.
Per my Chilton's manual tehe bolts should be (cold engine) 65 to 72 FT. Pnds., the cam shaft bearing bolts should be 8x25 = 15 - 19 Ft pnds and the 8x65 should be 14 - 15 Ft Pnds.
The sequence is as follows for the (10 ) head bolts:
