Error: Memory
This message appears when the handheld device does not have enough Random Access Memory (RAM) to operate the StudyCards Viewer. If you receive this message, the StudyCards Viewer will exit.
Error: This stack can't be displayed. It has an unknown format.
Before opening a stack, the StudyCardsTM Viewer examines the contents to verify that:
• The file contains a StudyCards stack.
• Data contains no corrupt information that might cause the StudyCards Viewer to malfunction.
If validation fails, the stack will not open. If the last stack you opened before quitting the StudyCards Viewer fails validation when you restart the StudyCards Viewer, no stack will open and the splash screen will appear.
If you receive either error message:
• Make sure the file is a StudyCards stack.
• Try to open another stack.
• Make sure you have the latest version of the StudyCards Viewer.
There are many reasons a calculator will report an error.
Simple calculators usually only report errors for math operations that are not possible such as dividing by zero or if you hit equals when there is no number between a math symbol ( 3 ++ 4 = ERROR)
For more complicated calculators like the TI-89 an error can come up due to such mathematical errors and there is a lot of room for error with more complicated equations. Also there are programs in the calculator that if not done correctly will crash and cause an error.
The instruction booklet should have a list of common errors and how to avoid them. Look at the table of contents or the index to find such a list.
Good Luck hope this helps.
