SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
SOURCE: cannot program garage door transmitter
Depending on the type of vehicle home remote system you have and the type of garage door opener installed will determine how you program the system in your vehicle.
Below is a web address for the owners manual to your Buick. It will show you step by step how to set your Buick's remote system to open your garage door.
Good luck.
Regards,
http://www.extendedgmwarranty.com/owners-manual/buick/2007-Buick-Rendezvous.pdf
Testimonial: "Perfect, thank you!"
