SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
SOURCE: Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
SOURCE: 99 minutes
It sounds like you may need a new timer. Has water or anything gotten into the timer. This could be causing a short or faulty reading in it.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
