You have 240Volt T104 Intermatic timer.
The clock works, and the spa works so voltage to the timer and spa are good.
You have push button control located on spa, and it stopped working.
1) The push button does NOT control the timer. T104 is mechanical timer, and the push button cannot activate the switch contacts, and there is no solenoid inside the timer that gives that option.
The push button is a separate problem from the timer.
So replace the push button.
Example push buttons at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?op=search&N=10866&in_dim_search=12) Timer problem.
What does the timer do?
If you have a push button, why do you need the timer?
T104 is mechanical single-channel non-electronic timer, and cannot override the push button once the push button is OFF. They make industrial timers that can perform multiple functions, but T104 is not in that category.
This makes me think the timer dial does not have trippers mounted on the dial, or the trippers are worn down.
Maybe the timer function is by-passed. Maybe all wires are on terminals 1 and 2.
Check how the timer is wired, and then add a comment.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
