My xbox was working and it cut off 5 mins into me playing, the power supply light turned red. so i unplug evrythng plug it back up, the light is on standby, try to turn it on and the light turns green for a split second and goes red and stays red.theres no red ring on the console and i dont think its the power supply since i used it to start another xbox and it was fine...what do i do how do i fix it?
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
I wouldn't recommend messing with it. The power supply is defective, and messing with a power supply is very dangerous. get a new power supply, just make sure that it is compatible with your xbox(there are 3 different versions of xbox power supplies out there)
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three connections are firmly secured.
Turn your console back on. Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
Did you let it heat up untill you get the 2 red rings. If not unplug your fan; turn it on and wait untill you get lights 1 and 3 flashing. turn it off and wait a couple of min. then plug your fan in and add the wind tunnel. then turn it back on. If it still doesn't work you did the X-clamp fix wrong.
Alright, lets fix this!
Xbox 360 power supply light is orange or yellow. Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all. If it's still doing the same it will be definitely a fault with the Xbox 360 power supply. So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red. There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply . So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply . You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord. Hope this helps you out! Please don't forget to rate :)
Try this method :
Check if your XBOX 360's Power Supply has an orange or green light. If it is RED, then unplug the power supply from the socket.
If it is orange or green, then try and unplug the Power Supply from the Back of your XBOX, wait 1 minute. Then plug it back in.
If that doesn't work then call 1-800-4MY-XBOX and speak to a XBOX Representative.
Sounds like there is something wrong with the Xbox 360 power supply,
try unplugging the Xbox 360 power supply from the console and unplug
supply from the power cord. Give it a minute then reconnect it all
back, also try it on another wall outlet without any extension cord at
all.
If it's still red that suggests fault with your
Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
