Hotpoint First Edition FEW12 Front Load Washer Logo
Posted on Jul 31, 2008
The 3 buttons
Hi , what are the three buttons for that are above the door. The markings have been rubbed off.The machine cycle seems to be on a vey long time.Perhaps due to these buttons.Thanks for your help.
  • rjs0159 Aug 03, 2008
    Hi Sue,thankyou very much for your solution your have been most helpful.Richard.
Anonymous
Level 1:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 24 Answers
  • Posted on Aug 02, 2008
Anonymous
Contributor
Level 1:
Teacher:
Answers
24
Questions
Helped
29796
Points
50
Button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
1helpful
Bosch Logixx 8 door seal rubbing why?
That will usually happen when the bearing is worn or the shaft has moved on the seal.
Wayne dalton 3018
Release the garage door from the opener and open the door by hand, if it is vey heavy you may have a broke spring inside the torsion bar above the header, check then to see if the opener goes through the complete cycle O K with the door not attached. If you don't have a broken spring you may need to increase the up force on the opener head.
LG dishwasher LDF6920ST - Power button lights up but the cycle buttons stopped working so the unit wont turn on to wash. The Power Scrub cycle button seems to be pressed down farther than the other...
Hi Mark.
Modern LG appliances retain settings even after you disconnect the power cord. The machine is reset opening the door and then pressing and holding the Normal and Delicate buttons at the same time for 3 seconds.
You can also try running the test mode shown at page 12 of the service manual.
If the machine is non responding and there is no code on display, then the problem is likely control module or control pad. Since the control pad looks defective, that is probably the part to replace.
Disassembling is shown in exploded view and service manual available using the links below:
Parts and diagrams are available here.
A copy of the service manual covering several LD models has been uploaded here.
Regards.
Ginko
The door on my hoover nextra washer drier sometimes does not open and I have to put the machine on a further cycle and then wait for the door release mechanism ot click and then open the door quickly
the clthes may be getting a false sensor reading that there still damp it may be vey humid,after a load of clothes try running some bleach through only put on heavy duty wash and extra rinse,the machine my have residue from softener. so sanitize machine a few times.
Front door wont close control locked light is on
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
4helpful
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
13helpful
2answers
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
4helpful
Spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
SPIN CYCLE PROBLEM
Replace both the wax motor (part of door lock),2nd,at the same time replace the main upper Control board.You will solve this problem.
133helpful
11answers
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
