Need ethernet driver for hp pavilion 725n also cannot connect pc to internet to check for update. must be able to download to flash drive and transfer data. No restore disks. Hard drive crashed. no backup data.
You can down load the driver from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=311249#N228
good luck.
You need the driver for the modem.Try to install in the device manager manualy.
Select networkcard right cilick and select properties select driver and select update driver
select the modem file you downloaded and press ok.
you maybe have to restart when you have done that.
Is your internetconnection protected with a code so it cant gain access ??
The lan connection has to light diodes one flashes orange and one flashes green
When it do that it haves connection.
Try to update the other drivers especialy them for the sound card and the graphics before you
install the driver for the modem.This could make a conflict so you cant install the driver properly.
Post me again if you cant get it to work
the dial up modem is working but I do not have a dial up service
I have DSL and it uses the Ethernet plug and is connected to a router.
The Ethernet Plug is intergrated into the motherboard
So here is what I found for the solution
I got the info from the motherboard ASUS A7N8X (HP 725n)
went to the ASUS website and got all the drivers for the intergrated parts including the ethernet plug. Here is the link to the website. http://www.nvidia.com/object/nforce_udp_...
I Thank you for your help! While searching on the net, I found many people that have had the same problem as I have. The restore feature is partitioned on the hard drive and if you dont make a back up restore disk and your hard drive crashes or frys out...you loose all the motherboard drivers for your parifials. The HP web site does not offer all drivers for this pc since it is outdated. I hope this might help some one. Rob.
peripherals
Have tried to get driver from HP website but ether not available or I'm not geting the right drivers
I got the usb to work as well as the card reader and modem from drivers for the motherboard but still no ethernet. If I am missing something at the HP website please let me know cause I aint gettin it?????
peripherals
