DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
SOURCE: Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
SOURCE: LAN ports not working
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
