It is not latching on to the soundbar transmitter. Is the locked light on the device turning on.
Wireless devices are sometimes known to drift. Is the sub silent when the soundbar power is off ?. Even then if its making this sound, the subwoofer amplifier is oscillating at very low frequency. You will need professional help and needs to be repaired.
Distorted sound from the Soundbar.
Change the Trim Level switch setting to a higher number.
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The woofer seems to have interference with its wireless signal.
Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
