Fisher Price Ocean Wonders Cradle Swing Logo
Posted on Mar 10, 2011
Hi, I have a fisher price Papasan Cradle Swing. even though the mobile is working, the motor stopped working[its not swinging]. Is there any way i can get it repaired? my 9 month daughter finds hard time to sleep at nights without swinging motion.
  • mi st Aug 01, 2012
    I have the same problem with my swing ( motor stopped working) and I cannot find replacement motor anywhere. I looked on mattel website.
  • Anonymous Nov 22, 2012
    Air wick has the same motor
oddduck
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 10, 2011
oddduck
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
11658
Points
86
You can purchase replacement motors from Mattel (Fisher Price's parent company).
It will be one of the following 3 products, just pick the one that matches what you have now:
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58050
https://store.mattel.com/ItemDetail.aspx?cat=140&item=59702
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58374
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
2helpful
2answers
I need a new worm gear for my fisher price starlight papasan cradle swing.
I found a set of worm gears that has 2 of the gears you need.
Google search, worm gear svm-103. It is a packet with a lot of worm gears but the 2 big ones work perfectly.
1helpful
My Starlight papasan craddle swing clicks loudly and the gears seemingly miss causing it to not swing properly whenever I put my baby in it (he only weighs 8 pounds). When there is no weight in it, it...
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Hi there, how do i adjust the chair on the fisher price starlight papasan swing? It is laying pretty low and i want to adjust it for the baby to sit more upright
If you haven't already figured this out, there are two pressure things on the underside of the swing. Just sit to the side or back of it to see them, push them both in, and tip it into the position you want. The upright position isn't upright like a chair, it's still a little reclined, so if you need a boost just slip a rolled up blanket in where you need it.
2helpful
I am looking to order replacement mobile fish for the Fisher Price Ocean wonders swing
These stuff toys on the mobile are not an available replacement part from Mattel.
They are available on eBay from a few different sellers though.
2helpful
I would like the manual instructions for the fisher price nature's touch papasan cradle swing
You can get the manual on the link below. It is not yours. It is just like yours though diffrent name.
http://service.mattel.com/us/product_detail.asp?id=K7924&Ntt=K7924&Pn=1&Brand=Fisher-Price+Babygear&Cat=Swings
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 26, 2010 • Toys
Top Fisher Price Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
