Code p 0368 refers to a camshaft position sensor B bank 1 -- circuit high===causes wiring short to positive --CMP sensor--ECM
code p 0492 refers to secondary air injection system bank 2---malfunction===causes wiring---AIR solenoid ---hose connections ---mechanical fault
playing with a climate control setting will not affect those codes so I suspect that you are being given the old run around
find yourself an accredited professional service center that has experience on your make of car and get a proper diagnosis and quote or if you have any sort of used car warranty , take it back and don't let them fool you again as you now have the codes facts
SOURCE: Audi A4 instrument cluster does not work
Your dash has what is known in the trade as a dry solder joint in the instrument cluster it will have to be repaired by people whom specialise in this work.
You could try BBA remanufacture as they do a lot of this type of work for us.
SOURCE: radio reset code for 1999 audi a4
Should be in your owners manual or in your glove box. If not the dealer will do this for your free of charge. And many honda for one has a place on their website to retrieve this info. It may require you pulling the radio to get the number on it so that they can retrieve this info. But I called a dealor for someone here last week and got them the code.
SOURCE: replace blower motor
check out http://forums.audiworld.com/forum
tons of help to be had there.
SOURCE: A6 engine ''deep rattling'' noise
go to scottykilmer.com - i use this guy a lot - you just have to sign in - first name only! or whatever you want to call yourself. it is 100 percent free and he is an expert on all cars - you can expect an answer within an hour or so! this guy knows more than one person should know - trust me - no fee for free info? cant go wrong
SOURCE: 1999 Audi A4 Climate Control Removal/Installation
You have to remove the trim panel around the stereo/climate control to expose the screws that hold it in place. Once you do that, and the screws are removed, it pulls straight out and unplugs. No need to disconnect the battery and no tricks to it once it slides out.
